New flywheel or no?
After reading through this thread, am I understanding that I can just re-use my old GenV 454 flywheel for my new build 454 bored over to 496 and stroked?
flywheel
I did buy an upgraded harmonic balancer. no way I’d use the old one on a motor making double the power.
flywheel
I would go with the ATI for sure. One thing with the ATI damper. They almost always need the hub to be honed to get the proper interference fit. They are almost always too tight. If you order it directly from ATI and you have a way to precisely measure your crankshaft snout, they will hone it to the correct fit. Otherwise most good machine shops should be able to do it for you although a lot of guys do not have the correct mandrel for the rod hone to do the job.
