Old 454 distributor >
Old 454 distributor
Old 454 distributor
Old 05-06-2023 | 07:38 PM
Default Old 454 distributor
Looking for an old dist to convert into a oil pump drive tool. Idea is to remove cam gear and cut top off the dist shaft so I can attach a 1/2" drill. Don't need pickup coil, reluctor, etc.
zz28zz is offline
Old 05-07-2023 | 06:13 AM
any small or big block dist will work just cut the teeth of the gear
boostbros is offline
Old 05-07-2023 | 06:22 AM
SB
If you don’t find a cheaper used one, $41 free shipping china hei’s on amazon. 4.3/5.0/5.7/ 7/7.4l….same length.
SB is offline
Old 05-07-2023 | 12:44 PM
they are $21 on summit not even worth trying to DIY one IMO
https://www.summitracing.com/parts/SUM-901015
sailtexas186548 is offline
Old 05-07-2023 | 03:12 PM
​​​​​​​The ones I remember had a roll pin attaching gear to shaft.Drive out the pin and the gear slides right off.
zz28zz is offline
Old 05-07-2023 | 03:17 PM
Originally Posted by sailtexas186548
they are $21 on summit not even worth trying to DIY one IMO https://www.summitracing.com/parts/SUM-901015
​​​​​​​Can those be used hands-free?I need to build oil press with exhaust manifold off to find oil leak down low somewhere.
zz28zz is offline
Duplicate post.
zz28zz is offline
