Lifespan on Bosch 4.9 02 Sensor
Exhaust risers are dry to transom.
AEM Uego kit Installed in 2019. Sensor never came out of riser and I monitor af/r while engine is running. I have power to gauge/sensor wired off a rocker switch on dash. AEM states to never operate engine without power on gauge/sensor.
I have read others opinion to not power up sensor before starting engine. Idea is a hot sensor porcelain is hit by cold engine start condensation and slowly damages sensor?
My gauge started showing full lean yesterday. Will replace sensor today. From reading online it seems I got my moneys worth from sensor?
What's everyone else's experience?
I've gotten about 8 plus years running full time in a marine environment.
You could pull the sensor and free air calibrate to see if there is any life left. I've done that as per the Innovate instructions for the sensors I use with them.
Moisture in some boat exhaust kills sensors faster then in cars, two years is pretty good though, I use these Innovate directional HBX-1 3729 protectors when tuning customers boats on water, the sensors last alot longer:
Attachment 577696
Attachment 577696
This makes no sense. What about the bazillion cars running wideband? They don't seem to be suffering at excessive rates..
Seems there is a very small sweet spot...don't want then off when running...can't have them on and too hot when starting.
A lot of Marine engines are using wide O2s at this point, why is there no marine O2?
Fuel pressure, activated...you mean when using a mechanical pump?
Would wiring it to activate with oil pressure be a better solution?
Adding manual O2 sensor switch to the pre/post engine running would remove a lot of focus that needs to be elsewhere.
Innovate protection bung, does it still get accurate readings?
