Port Side Starter Replacement 496 Twin Engine
I need to replace the Port Side Starter and access is a nightmare.
From what I can see I need to pull the hoses, the Riser and the Manifold. Might as well replace the knock sensors while I'm there...
Looking for advice on an easier way to do this other than pulling the engine.
Thanks in advance.
Thanks in advance.
Thanks in advance.
Thanks in advance.
havent done one of those but the last time I changed a starter in tight spaces I put a small flat strap around the solenoid so it held the weight from above so I did not have to hold all the weight from down in the bilge. if you have someone above to lift and lower it so you can just move it into place and start the bolts it is easier.
Honestly, I’d just pull the motor.
6 bolts to remove drive, 2 bolts to remove exhaust clamps, 10 bolts to remove engine if you have offshore mounts. Raise motor a foot or two, replace starter and lower back down. You can possibly get away without removing grounds, water hoses, etc……
Im an incompetent accountant and can have one out of the boat and on the ground in an hour or hour and a half at the most including set up time.
Fast forward to current time and the reason I'm replacing the starter is the tech left the nut loose that held the terminal lug to the starter solenoid. The lug is arced all to hell and the end of the terminal lug is burned away.
Now I know why my engine was out of alignment back in July and I found the engine mount bolts were left loose. I couldn't figure out why those bolts were never tightened. Until now...
