"Stainless Headers Inc." Marine Muffler Inserts - any experience? Like GGB Extreme? >
Old 04-30-2024 | 09:31 PM
Default "Stainless Headers Inc." Marine Muffler Inserts - any experience? Like GGB Extreme?
I stumbled on these today: Stainless Headers Mfg. Inc. Marine Insert Muffler
Has anyone used these? Was hard to search the keywords given the number of results for "stainless headers" on here.... Curious how well they reduce the decibels and whether or not they slaughter the performance. It seems like the Hardin HCX Competition series for comparison slaughters the performance.
It seems like everyone loved the GGB Extreme inserts but they don't make them anymore and I can't find them for sale anywhere. Wondering if these could be similar. Trying to find mufflers (bolt on or inserts) for a dry exhaust application.
Here's a pic from their website:
And here's a couple pics of the GGB's for reference since I mentioned them. I think these are correct, they're the only pics I found online from nearly 20 years ago:
RockyS18 is offline
Old 05-01-2024 | 03:33 AM
SB
The Stainless Headers inserts sure look like what GGB inserts used to look like.
Here are the Stainless Header ones . Pic from their site:
SB is offline
Old 05-01-2024 | 04:32 PM
How much HP? ID of your tailpipe?
LSXCJ is offline
Old 05-02-2024 | 11:54 AM
1000hp. I have water jacketed headers and tailpipes that exit out the top of my hatch, with the water outlet redirected to the transom. The tailpipe OD is 4.5", which I could bolt a muffler on to stick high out of my hatch, or I could install some additional piping to slide inserts into, same effect.
To get more complicated, my water jacketed tailpipes are long/straight enough to install a slide in muffler as well, they're 3.86" ID with the jacketing. But there's a minor dimple where the water outlet is welded, and I can't drill into the jacketing, but could drill into the larger ID edge/tip of pipe right after the jacketing ends. In the tailpipes I have 11" of straight length to work with, plus I normally run turn-downs slipped on to them (to shoot exhaust back), which could give me a few extra inches to work with, but with a larger ID. Or I could do some combo of a smaller OD slip in muffler to my tailpipe if I can secure it properly, than a larger OD muffler bolted to the tailpipe. Just trying to figure out what product options I have to work with.
I'm know the dry exhaust mufflers won't work as well, and I'm sure I'll lose some power, but I just need a removable dry solution for when I'm not on the race course.
RockyS18 is offline
Old 09-29-2025 | 09:22 PM
They look identical to the GGB insert. Only difference i can see is the space between the rings appears a bit larger on the GGb VS. the stainless header insert.
xlint89 is offline
Old 10-03-2025 | 04:40 PM
The stainless headers seem to knock the edge off and no loss in performance. My engines are close to yours. I ran gab until they fell apart. I bought the 8 in long. Still noisy,but ok
PPlay33 is offline
Old 10-04-2025 | 09:01 AM
Mbam's Avatar
Offshoreonly Advertiser
These are some mufflers I made for my BAM Cigarette (RIP). Gaffrig & I sketched out the original design on a napkin at Bootleggers in Ft Lauderdale
1000 HP with Y pipes.
No difference in power open or closed. Made for 5" tail pipes and built to last.
Not pretty but will for sure do the job. Water feed is hidden, 1" hole in top of tailpipe. My tailpipes were really close to the drives, Bottom shows the result from trimming all the way up..
Make offer if interested.
Mbam is offline
