Bravo xr ITS sportmaster rigging? >
Old 06-23-2024 | 11:40 AM
Default Bravo xr ITS sportmaster rigging?
Hi, going from standard bravo 1 drive/transom assembly (4.7" propshaft height) to a bravo xr -2" sportmaster with ITS transom assembly. Question is how much i can go up with the sportmaster and the 8" setback the its gives? My old engine made +500hp and really liked how it perfomed, easy planning, plenty of bow lift at cruising speeds untill 60mph when it started to porpoise with all the props i have tested
, many 4 blades and hydro p5x. New combination is going to be approx 650hp/ with the xr sportmaster ITS. 26ft, 24dg straight v-hull, 5500lbs.
JaniH is offline
Old 07-20-2024 | 01:45 PM
Test fitted and measured, propshaft 2.7" below the bottom. Have read that for every inch of setback you can go 1/8" up, ITS gives 7" setback. I only have 1/2" spacer to try.
JaniH is offline
Old 07-14-2025 | 04:44 AM
First water test maybe at the end of this week. I have dilemma should i try without spacer first, prop shaft 2,7” below. Or should go with 1/2” or 1” spacer, i have both.
JaniH is offline
Old 07-14-2025 | 12:10 PM
Bravo style props don't like to be surfaced. They will sling blades if they are.
snapmorgan is offline
Old 07-14-2025 | 12:45 PM
Thats what i have heard too. They say the sportmasters works better being high, and cause transom lift being too deep. I really think the stock lower case would be better for my combo, but you newer know. My quess is 75mph if i am lucky.
JaniH is offline
