500 efi electric fuel pump >
Old 06-25-2024 | 12:10 PM
Default 500 efi electric fuel pump
Does anyone know how big a job and how long it takes to replace the electric fuel pump for a 500 efi in an 01 29 Fever?
BigMeaney is offline
Old 06-25-2024 | 12:16 PM
F-2 Speedy's Avatar
If its cool fuel mounted down underneath the port side motor mount it could be a challenge
F-2 Speedy is offline
Old 06-25-2024 | 01:20 PM
On a single 29, no worries. On a twin, I did mine on the 32 and it was a PITA, like F-2 said. Under the motor and you pretty much have to hang upside down.
Wildman_grafix is offline
Old 06-25-2024 | 01:31 PM
jeff32's Avatar
In fact!
simple task in my triple
but in a 29 fountain.... ouch !!!!
might be a challenge!
unless the backseat lifts up with the hatch to access the front of engines?
or taking the engine out might be the solution... got a picture?
jeff32 is offline
Old 06-25-2024 | 07:18 PM
I'm pretty sure I saw it near the mount when I was draining the block and water pressure hose while winterizing it. Guess I'll be paying someone to replace it. I'll have to take a better look at it this weekend.
Old 06-26-2024 | 05:31 AM
articfriends's Avatar
ON a stock 500 efi the fuel pump is mounted underneath the front of engine under or slightly behind the harmonic balancer. You would disconnect the water lines to the fuel cooler, disconnect the fuel lines then take nuts of the studs o the mount that hangs down near bottom of your front accesories. Some boats you can have that out in half hr
articfriends is offline
Old 06-26-2024 | 08:26 AM
F-2 Speedy's Avatar
Yep, Smitty is right, I was thinking 502 mag efi, it mounts on the bracket bolted to the studs on each side of the block bottom of the front of the oil pan
Old 06-26-2024 | 12:12 PM
Well I guess imgonna have to give it my best college try. Nobody near me cantouch it for at least 2 weeks. Has anyone who's done it used a pump other than the $900 Mercury pump?
Old 06-26-2024 | 01:23 PM
wieland77's Avatar
I used this pump and have been for over a year with no issues, at the time couldnt find an OEM pump and this seems like an exact replacement. Price isnt bad either lol
wieland77 is offline
Old 06-26-2024 | 04:52 PM
Big difference in price there. And it will work for 500 efi? I only saw black models in description. How about any "specialty tools" to do this job? The boat is over an hour away from my house and I like to have everything I need with me so if I do need to go get something, it'll be beer 🍺
