Cafe Racer Deck Hatch issues >
Old 07-29-2024 | 06:13 PM
Default Cafe Racer Deck Hatch issues
What have you guys done to prevent leaks? First time mine has seen rain since I’ve owned it this past weekend and noticed it coming in through the hatches. Seen on lip ship they have seals but are they for the Cafes? My seals SEEM to be ok but I wouldn’t be surprised if they are the original ones and are just worn and flat from time.
87CigCafe is offline
Old 07-29-2024 | 07:39 PM
seafordguy's Avatar
Replace seals with lip ship OEM.
make sure you get them placed so they seal properly.
make sure your drain holes are clean so water doesn’t puddle up.
seafordguy is offline
Old 07-29-2024 | 07:59 PM
Default ?
drain holes you speak of haven’t spotted those? Inside hatch rail?
Old 07-31-2024 | 02:25 PM
Default Holes in the deck go into the back of the hatches
Hopefully this shows the holes properly
TICafeRacer is offline
Old 07-31-2024 | 08:36 PM
Default Awesome!
actually makes sense now! Mine looks to have been covered up by something at some time.
where do they drain to?
thanks!
Old 08-01-2024 | 06:21 AM
The backside of the inside of the hatch by where the strut connects. I will try to take a picture today and show it.
Old 08-01-2024 | 07:21 AM
Default Thanks!
man I sure appreciate it!!
Old 08-01-2024 | 08:46 AM
Default Second attempt
Here it is. I tried once and something went wrong. It is the hole under the screw on the right.
Old 08-02-2024 | 12:02 PM
seafordguy's Avatar
I think they are molded so you may be able to blow them out with compressed air……
Old 08-02-2024 | 12:13 PM
Looks like a raised fiberglass rim covered completely by the hatch? The only way they would leak is if the drain was plugged and the captured water is sloshing when running getting past the seals, or totally full and weeping past bad seals?
Tartilla is offline
