Hose question????
Hi all, quick question.
I traded into a 1991 Baja bandit that came without motor and most of the out drive.
no big deal I think I got the better end of the deal as to what I traded it for.
anyways, today looking it over I saw these 2 hoses and outlets mounted to the transom near the exhaust outlets and am wondering what they were/are for???
is it possible this was one time a dry exhaust and they routed the water through there or am I missing something else?
also while we’re at it, I decoded the serial numbers on my outdrive case and accord to what I found it says it’s a Aplha 1 gen 2 drive?
surely that’s not factory for a bandit is it?
if so how hard would it be to switch everything over to a bravo 1 if I wanted?
I included some pics so you all can see what I’m talking about.
I circled it in red.
thanks
print screen windows xp
thanks
definitly for dry exhaust those 2 hoses !
to switch to bravo, you are going to fill in the transom ( read redo transom) and cut hole for bravo making sure sure X dimension or the height of your drive will be perfectly at the right height to be able to plane, and reach the best top speed possible !
Measure twice...
Cut once!
Measure twice...
Cut once!
are you sure you run an alpha drive? not that many dry exhaust on small block, and i would guess it was a small block because of the drive...
and if you want to use a bravo, i would think you would use a big block, and the exhaust holes won't fit either because of the larger block...
That’s a bravo transom assy.
The most noticeable difference is the shift linkage on the alpha,
It’s not there, just the cable that sticks out of the bell housing on a bravo
I had a 91 bandit, cool looking, fast, fun boat, ride wasn’t great unless you were on relatively smooth water, due to the 15* bottom
To go from an Alpha to a Bravo I believe you just need buy all the Bravo components. Coupler, transom assy, bell housing etc.. And drill the 2 extra holes for the transom assembly and install. No big deal since the engine is already out.
