Fitting material >
Fitting material
Fitting material
Old 11-25-2024 | 12:52 PM
Default Fitting material
Nickel Plated Aluminum AN fittings vs Anodized for fresh water lines. What have you had the best luck with?
jeffswav is offline
Old 11-25-2024 | 02:25 PM
Originally Posted by jeffswav
When using -16 AN fittings for fresh water use, what material holds up the best? I have tried Black and Blue/Red aluminum fittings. Both only last about 4 years before corrosion on the inside begins. Anyone try nickel plated aluminum?
Ayuh,..... Stainless steel,....
Bondo is offline
Old 11-26-2024 | 01:38 PM
Feel free to post a link for a stainless steel -16 hose end in a 45 degree.
jeffswav is offline
Old 11-26-2024 | 02:05 PM
If you know someone with a TIG welder I'm sure you could make one if you can't find one.
Ryanw10 is offline
Old 11-26-2024 | 03:11 PM
Teague has a lot of high-end stainless etc. worth a call... VERY nice fittings I may add.
Diamond Dave is offline
Old 11-27-2024 | 07:51 AM
Ayuh,..... 45 Degree - Stainless Steel Hose Ends - Products
Bondo is offline
Old 11-27-2024 | 09:37 AM
These are not AN fittings. Looking for something like this https://www.summitracing.com/parts/s...SABEgKP5vD_BwE
jeffswav is offline
Old 11-27-2024 | 10:16 AM
I found the stainless pipe fittings but Bob only has the stainless hose fittings in push lock.
jeffswav is offline
Old 12-01-2024 | 02:57 AM
nothing wrong with push lock
mike tkach is offline
Old 12-01-2024 | 10:19 AM
agree, what are you using these for? push lock is good for 300psi on average and I dont know of anything getting near that on a boat other than the trim systems.
compedgemarine is offline
