Why is this plumbed this way?
I am working on getting this Superboat going. I have a really bad boat problem. When I bought the boat I new the engine had taken in water and needed to be replaced/rebuilt. The owner said the boat overheated and cut out. His mechanic said the engine overheated and caused the exhaust manifolds leaked water in. I am in the process of removing the engine now.
I have never seen water routed this way? I have always plumbed incoming water to a crossover in the block then the water circulates through the block to water outlet/thermostat housing and then to exhaust manifolds. As you can see in the photo incoming raw water goes to a "T" in the block which then goes to the water outlet? To me this wouldn't pass water through the block necessarily? All may be diverted to exhaust manifolds?
I don’t know that it was the head gasket? Do you see something?
On the forensic examination the raw water pump plastic body had a section missing so I think it overheated. Both banks had the same water in them so I don’t think it was an exhaust manifold because I don’t think 2 would fail at one time. I think water got sucked back into the engine from the exhaust. Flappers not working.
