Any idea what this is? >
Old 01-14-2025 | 08:46 PM
Default Any idea what this is?
Hi guys,
got a question, looked at a boat yesterday and the below pic is got me wondering what it might be.
the engine is a 454 mag efi with what the guy says got water in the oil.
he says he shut it off and hasn’t done anything with it.
this “material” or “stain” is between the head and the block on both sides middle cylinders both sides.
any ideas what this might be?
thanks.
Tom272Baja is offline
Old 01-14-2025 | 09:30 PM
Looks like block was froze and then JB welded
Ryanw10 is offline
Old 01-14-2025 | 09:34 PM
So cracked block?
Old 01-15-2025 | 04:54 AM
SB
If your hot for the boat Price it as it needs a motor and present one not rebuildable.
SB is offline
Old 01-15-2025 | 05:49 AM
jeff32's Avatar
Originally Posted by Tom272Baja
So cracked block?
that would be my guess
water in oil dont spill out the block like that for sure!
jeff32 is offline
Old 01-15-2025 | 06:01 AM
Sure looks like JB weld to me with water staining underneath. So yes, definitely cracked block, and being that your getting water in the oil, I would presume that engine is worth no more than scrap metal.
Ryanw10 is offline
Old 01-15-2025 | 08:51 AM
F-2 Speedy's Avatar
Fubr
F-2 Speedy is offline
Old 01-15-2025 | 09:15 AM
Being it is the same on both sides you still think cracked block?
what are the odds of that?
i (just my thinking) was even thinking that the heads were lifted because it’s both sides and 2 center cylinders each side.
if consensus is cracked block then I imagine you guys are most likely correct
Old 01-15-2025 | 09:51 AM
F-2 Speedy's Avatar
My guess, improper winterize at some point froze and busted
Old 01-15-2025 | 09:56 AM
Very easily can crack on both sides of the block, as there is water in both sides of the block.
Ryanw10 is offline
