cleaning resevoir
Old 06-15-2025 | 10:29 AM
Default cleaning resevoir
About to change the drive lube on my XR and also want to clean the reservoir. What is a good for cleaning it. Alcohol???
Thanks,
Padraig
Padraig is offline
Old 06-15-2025 | 12:26 PM
Thanks,
Padraig
I’ve used kerosene with success… and shake the bottle around.
MyIsland3 is offline
Old 06-17-2025 | 12:42 PM
Anything known by the state of cancer to cause california will do..
Old 06-17-2025 | 01:46 PM
You want something that will suspend the contamination so it can pour or eipe out etc. Even warm water with a detergent would work...
Depends on where you are...water also causes cancer...in CA.
Tartilla is offline
Old 07-01-2025 | 05:03 PM
Thanks,
Padraig
Just curious what you used. I tried acetone last night, no good. It liquified the small amount of blackish brown gunk on the bottom of one of my reservoirs into some nasty funk that’s now stuck to the entire inside of the reservoir.
Baja_260 is offline
Old 07-02-2025 | 04:40 AM
Mine wasn't bad and I used some kerosene as suggested.
Padraig
Padraig is offline
Old 07-02-2025 | 06:35 AM
Padraig
Sounds good, I’ll try that next. Thanks.
Baja_260 is offline
Old 07-02-2025 | 06:42 AM
I use mineral spirts, a rag and screw driver the wipe it clean every change. Of course the bottle is off when I do this.
Wildman_grafix is offline
Old 07-02-2025 | 07:23 PM
That’s the trick, gotta get in there with a rag and a tool to wipe it all out. I was hoping to just dilute it down with a solvent then shake it up and dump it out. No big deal.
Baja_260 is offline
Old 07-03-2025 | 12:23 AM
Acetone and plastic don't play well together in general. One of our mechanics left a screwdriver in a pan of acetone. Next day the handle had completely dissolved. I have mineral spirits in my parts cleaner. Works well on almost everything.
zz28zz is offline
