Push Length Valve Witness Marks- thoughts
Guys, I am in the process of getting some engines together. Ian measuring for the pushrod lengths and I’m struggling to get a good contact area on my intake valve.
I have a 454 mark iv block that was stroked and I have promaxx heads (290) installed. The cams have a 0.592 lift with my crowler 1.8 ratio rockers.
I have Johnson hydraulic roller lifters.
I at first started doing this pushrod length check merely doing the dye on the end of the valve stem and look for most center and narrow mark. But I found as I was most centered on the valve, the mark was wide. I then used the mid-lift approach. This ended up having me lengthen the push rod such that it put the mark on the end of the valve closer toward the exhaust port, BUT the mark was very narrow.
The exhaust push rod witness mark looked good, first photo.
Exhaust valve marking
The intake valve is another story. To get a narrow mark I have to have that rod fairly long, such that it puts the mark near the edge of the valve. On top of that, I most likely need a longer stud for here. 2nd photo, close to the mid lift process. The 3rd photo is of a shorter rod and as you can see the witness mark is centered but very wide.
Intake mid lift approach.
Intake valve shorter pushrod centered mark but wide.
So, the question is, what can I do to get the intake looking like the exhaust?
Did you buy the heads assembled or bare ? What valves did you use ? I wonder if a shorter exhaust valve would help if it doesn't mess up your installed hgt too much. I have never used a Promax head so I dont know how the geometry normally works out.
Yes the heads came assembled. I had them upgraded with inconel exhaust valves and heavier pressure PAC springs for my cam. The valves are stainless on the intake.
if those offsets from crowler are there for the stainless rockers, could be nice.
I ran into this issue building a 383 stroker years ago. Someone suggested swapping the rockers around. Didn't make any sense at all but out of desperation I tried it. Somehow it worked. Still scratching my head over that one.
The only rockers I have are 1.8 ratio and I’ve tried a couple, they all yield the same result. I’d say you may have had different ratio rockers on exhaust vs intake.
I just did another test with as best as I can to mid-lift approach. I had to shorten the rod to get a more legible mark on the valve stem vs being off further.
below are the results of that test and then with a micrometer. I measured center of mark to back toward center of valve. The largest offset crower has is 0.090 so I’m thinking that’s what I need.
do you agree?
Micrometer reading.
Best I can get mid-lift approach while keeping a mark on the valve.
do you agree?
Micrometer reading.
Forgive me I run solids.
But, how are your lifters not collapsing with the springs in and no oil pressure? Wouldn't this throw off the contact pattern? I believe I used test springs on my last HR builds.
All right…. Update guys, need to hear your blessings on if these are ok.
Below is the repeat of the exhaust valve, which I think looks good. Estimated contact pattern width is 0.042”.
Exhaust
As suggested, thank you, I picked up an 0.090” offset rocker and below is the intake pattern, estimated at 0.056” width.
Intake
Am I good to go and move on to the next stage of this build?
Exhaust
Intake
The original exhaust pic looked not bad. Was narrow and relatively centred,
The exh you just posted is not like that˙ at all.
I wouldn't run the exh the way it is. Too far off the center, despite being narrow.
The intake looks far better now. Would the 0.050" have place the contact patch in the center vs where the 0.090" pulled it past center tonthe other side?
