Interesting Mercury engine >
Old 11-26-2025 | 11:51 AM
Mbam's Avatar
Offshoreonly Advertiser
Default Interesting Mercury engine
I learn something new every day.
Buried and hard to find on the Mercury website is a somewhat new engine from the Quicksilver division. It's a flat plane small block! Not exactly inexpensive but 5800 RPM, 400 horsepower. There are a couple of videos floating around. They sound so different from a standard V8.
Mbam is offline
Old 11-26-2025 | 01:33 PM
https://www.quicksilver-products.com...i-bravo-engine
LSXCJ is offline
Old 11-26-2025 | 02:52 PM
Marc,
The GM 6.6L block the use in the 2500 Silverado with the crankshaft out of the Corvette engine...? Just spitballing....
Thanks. Brad.
Brad Christy is offline
Old 11-26-2025 | 03:32 PM
That is wild. We discussed before. I’m surprised. Would love to see the crank or hear one. Makes a normal v8 exhaust configuration work better but you wouldn’t gain much until high rpm with a normal cast manifold. Unless that manifold is special too.
Could be beast with a healthy cam.
hogie roll is offline
Old 11-26-2025 | 03:36 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Little blurb I came across, from 3 years ago ( ! ) ?
Sydwayz is offline
Old 11-26-2025 | 08:30 PM
Default Thank you
Interesting indeed
Markus is offline
Old 12-01-2025 | 07:17 PM
They are interesting.
Ask Mercury how many they have sold so far.
cheech is offline
Old 12-01-2025 | 08:29 PM
What hull would you put them in?
Hoodoo 2.0 is online now
Old 12-01-2025 | 08:30 PM
Old 12-02-2025 | 02:55 PM
I was thinking about that. Not much out there small enough with a fast hull for twins where you wouldn’t rather have big blocks. Old 27 magnums were twin small blocks. Some old hustlers were too and could be fast with surface drives or bravos. You’d want a 26-30 twin, maybe a fountain 32
