Can you find these in white? >
Old 01-05-2026 | 04:41 PM
Default Can you find these in white?
Can you find any of these gauges or just the bezels in white? Redoing all the gauges to Autometer white marine and want to match somewhat.
Does the bezel of the drive gauge pop off without taking it out? If so I will just paint to match cause that doesnt look fun to take out.
Thanks!
PS - Off subject but do any of you higher power stereo guys (5k watts+) run a lithium battery just for the subs amp? If so what brand? Looking at Glowe Voltage series 3.
496 BB is offline
Old 01-05-2026 | 04:42 PM
496 BB is offline
Old 01-05-2026 | 04:46 PM
What's your thinking on incorporating a LiFeP04 battery? Adding as a standalone or replacing an existing flooded cell type battery? How are you planning on charging it if standalone? They have pretty rigid charging protocols necessary in order to get a full charge...just curious.
Baja 252 Islander
bajaman is offline
Old 01-05-2026 | 04:51 PM
Their batteries work off stock alternators. All thats needed is the initial charge after shipping with the lithium charger. Reason why is I have 2 newer West Marine deep cycles and they cant power the subs with engine off. Dont know if they can with engine on or not since its out at the moment. I know those batteries do just fine with the (2) 1200.4 amps I have for mids and highs. Just dont do the subs. I even added another in series yesterday while out in the shop and it dont help. Sound decent at very low volumes but once turned up past 30% they dont have power needed. Subs are on a 2.5K amp.
496 BB is offline
Old 01-05-2026 | 06:12 PM
You could just take them to a powder coater and have them done in white
Rons1 is offline
Old 01-05-2026 | 10:40 PM
The drive indicator is a complete assembly. The outer rim has studs that bolt it all together Marine Parts Plus Parts Search
I would loosen it enough to get tape behind it and paint it in place
Griff is offline
Old 01-06-2026 | 07:53 AM
When I did my dash and had panels made I had them make a new card for the trim gauges
Rons1 is offline
Old 01-06-2026 | 07:55 AM
Rons1 is offline
Old 01-06-2026 | 07:56 AM
Rons1 is offline
Old 01-06-2026 | 07:57 AM
Rons1 is offline
