Mirage Props Blowout/cavatation >
Old 12-12-2002 | 05:04 AM
HOUSTONPROP's Avatar
Question Mirage Props Blowout/cavatation
MANY BOAT OWNERS RUNNING Mirage props have been reported to have alot of cavation when turning or blowout when planing out /or trimming high we have found that just by adding some cupping to the tip and moderate blade thinning but still retaining durabilitly has increased speeds up to 6 mph and in the boating world thats alot. we thought we would let you know, props are like snowflakes there is not one the same .let us know if we can help your mirage prop kick as#######
HOUSTONPROP is offline
Old 12-12-2002 | 07:00 PM
Ric232
Darrin,
My Mirage Plus (which you should receive Friday), behaves like you describe. I'm looking forward to the better grip and speed.
Old 12-12-2002 | 07:15 PM
obnoxus's Avatar
Charter Member #1171
That explains alot,,, I have a 23 Mirage Plus that I have thinned and cupped and do not blow it out,,, I tried a 25 + after the motor swap and blew it out,,, Thanks for the Info !!!!!!!!!!
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 12-13-2002 | 07:03 AM
Apache22
also if you bead blast just the cupped edge of the prop it really helps it bite
Old 12-13-2002 | 08:06 AM
ric 232 prop
Originally posted by Ric232
Darrin,
ups arrives about 3:30 central time , I will let you know tonight that the prop makes it ok.
Old 12-13-2002 | 06:25 PM
ric232
Darrin,
Ric232 prop is here ,not bad just need to thin out and add cupping and hope that does the trick I will ship this out to you on Monday/Darin
Old 12-14-2002 | 03:30 PM
Ric232
Darin,
How badly was it out of balance?
Old 12-14-2002 | 09:38 PM
Question balance/ prop mirage ric 232
we'll ric 232 IT WAS AT THE END OF THE DAY when the prop arrived ,i was going to go put it on the balancer just because Iknew you would ask /but after doing 13 stainless they get heavy and I said the hell with it ,Iam going towork this SUNDAY and I will put it on there and Iwill post to YOU/ON THE BALANCE.I was just to LAZY AT THE TIME. TALK TO YOU Sunday evening and let you know/Darin
Old 12-15-2002 | 01:39 PM
bobby daniels
I BET IT DOES GET TUFF LIFTING THOSE PROPS !!!!!
Old 12-15-2002 | 04:40 PM
Ric232
No problem Darin. Since you said "not bad", I thought you had already started working on it. I'm not in THAT big of a rush. Anyway, I'd rather you work on mine early in the day when you're fresh.
