Gen 6 502 efi fuel pump question.
I’m building a couple of 502 gen 6 Efi engines. They run a Holley low pressure fuel pump. Then a high pressure pump ontop of a fuel cooler / vapour separator tank on the top / rear of the engine. The VST tanks are blocked. So wouldn’t cool anyway with no water going through. Iv stripped them and they are in a bad way. Looking at these numbers they are 120psi. Question is can I just run with no cooler. Vapour separator ? The tank has a float inside attached to the inlet manifold. ? So if I can find 2 new 120psi pumps. Run inline. Will they be ok ?
Ditch all the VST stuff. 120psi pump means nothing. VST systems run at about 30psi.
Get a marine efi pump that flows enough gph...like.... Mallory Ignition 11106M Mallory Marine Electric Fuel Pumps | Summit Racing
Then get a fuel pressure regulator and run a return line back to the fuel tank
https://www.demon-tweeks.com/uk/aem-...mp-aem50-1009/
If you don't have a port on your fuel tank to run a return line to, you can T into the fuel filler filler tube.
BTW, there is a wiring diagram in this thread about how to safely wire up an electric fuel pump. Belt driven raw water fuel pump assembly - Offshoreonly.com
Techinically not marine rated, but should work fine. Then use this regulator or similar Buy AEM Electronics Universal Adjustable Fuel Pressure Regulator - 25-302BK | Demon Tweeks
