A little play in the outdrive still >
Old 05-26-2026 | 07:59 PM
Default A little play in the outdrive still
1990 bravo 1 outdrive, had the transom assembly replace back in July ‘24 with an SEI. Decided to replace the entire transom assembly because of the play in it, it was from the steering pin being bent. It would lean to port when I would drive, pretty badly at that and now although not as bad, the lean is still there. In this video I’m both trying to move the outdrive and tape, so bear with me. It looks like the bolt on the front of the tiller arm is worn, shouldn’t that be an easy fix? Does it look like that’s the issue or maybe a worn tiller arm?
https://youtube.com/shorts/4hHS5q1gdmI?si=eNEvlf4s1bgOVwQw
Prestigeworldwideee is offline
Old 05-26-2026 | 08:13 PM
Hi, your video link does not work… at least it did not for me. So I’m an unsure where you are seeing the play or slop in the drive.
Question, when you replaced transom assembly from SEI, it included a new gimbal ring and upper swival shaft and new upper tiller arm?
If it had all those new parts, then yes I would say you did not secure the “tiller arm” bolt around the upper swival shaft well enough.
if you reused the tiller arm, then that in combination to not being tight enough is a good source of problem.
those are my thoughts so far.
MyIsland3 is offline
Old 05-26-2026 | 08:37 PM
Copying and pasting into the browser worked for me. The link is unclickable. The transom assembly did come with a new tiller arm but I didn’t do the work on it, had a shop do it.
Old 05-27-2026 | 09:03 AM
Not sure what my issue was….. but I got the video to work.
if the drive is not moving when you make that movement….. your tiller arm is an issue. If this has been going on for a while, the flats on the upper swival shaft could be worn as well.
To fix either of them, you still need to lower the swival shaft so you will have good visibility to inspect when replacing that tiller arm.
Old 05-27-2026 | 09:26 AM
https://youtube.com/shorts/4hHS5q1gd...Evlf4s1bgOVwQw
PWW,
What is inducing the movement? Are you wiggling the drive from the outside or are you sawing back and forth on the wheel? Do you have any up/down play in the gimbal pin?
Thanks. Brad.
Brad Christy is offline
Old 05-27-2026 | 10:26 AM
did i miss, cable or full hydraulic?
GLENAMY 242SS is offline
Old 05-27-2026 | 10:31 AM
Old 05-27-2026 | 11:44 AM
The tiller arm actually appears to be new, I re-looked at the sei website I got it off and it didn’t look like it had one but it’s new. I’m trying to get the clevis pin out but it looks like wire cotter keys, hard to get out.
Old 05-27-2026 | 11:45 AM
hydraulic assisted* and this is side to side on the outdrive. It’s not moving up and down, is the gimbal pin the clevis pin that’s moving back and forth on the front of the tiller arm? That seems to be the right size but possibly worn, that’s the pin you see movement in.
Old 05-27-2026 | 01:01 PM
I don’t have a micrometer but here’s the pin, 2.25” long
