Bravo Three stripdown and re-paint >
Old 05-31-2026 | 04:51 PM
Default Bravo Three stripdown and re-paint
Hey everyone,
New here and I'm trying to send a PM to buy a part. Instead of spamming an old post I thought I'd share a few pics of my project. Bought a new to me 2004 Doral Intrigue. Salt water had started to take it's toll on the finish, and one of the skegs had some damage from galvanic corrosion.
Sparkfarmer is offline
Old 05-31-2026 | 04:57 PM
Default Dirty ol' drive
Old 05-31-2026 | 04:59 PM
Default Galvanic corrosion on the skeg
Old 05-31-2026 | 05:00 PM
Default Tig weld repair
Old 05-31-2026 | 05:02 PM
Default Sandblasted drives
Old 05-31-2026 | 05:12 PM
Default C-IC 33 Aero (Alumiprep)
Drawing from my background in aircraft maintenance, I prepared the aluminum drives for paint using the same techniques recommended by aircraft manufacturers. Alumiprep is a phosphoric acid-based cleaner. It's used to remove the oxidation layer on aluminum. Only difference is I diluted the Alumiprep with water as the drives are cast. Come to find out, the Mercury Bravo Three shop manual recommends the exact same process. I only stumbled on that info afterwards while browsing the manual.
Alumiprep treatment
Alumiprep treatment
Old 05-31-2026 | 05:17 PM
Default Alodine
Immediately after the Alumiprep treatment, I applied Alodine to provide a good conversion coating to promote paint adhesion.
Old 05-31-2026 | 05:19 PM
Default Interprotect 2000e
I then sprayed 5 coats of Interproject epoxy primer
Old 05-31-2026 | 05:23 PM
Default AWLGrip
Then finished it off with 3 coats of AWLGrip AWLCraft 3000.
Old 05-31-2026 | 05:24 PM
Pretty happy with the results. We'll see how well it holds up.
