B-max/xr
Old 12-22-2002 | 05:58 PM
wil ros
Default B-max/xr
Maybe is a stupid question,but here it is.Can a XR lower be used with a B-MAX upper?Can the B-MAX upper be bought seperately?Thanks for any information.
Old 12-24-2002 | 10:26 PM
Mr Gadgets's Avatar
Charter Member #601
at one point I discussed this with a guy that had bought a Bmax. He had called Dean and asked him for a price on an upper only.. It was voice mail and I never did find out if it could be done. You might just call Dean at the Bravo Shop and see what he says..
Good luck
Dick
Mr Gadgets is offline
Old 12-24-2002 | 11:33 PM
WILDTHING TAZ's Avatar
B-MAX REPAIR
TO ANWSER YOUR QUESTION YES A XR LOWER CASE CAN BE USED.YOU CAN NOT USE AN XR VERTICAL SHAFT!! YOU MUST USE A B-MAX VERTICAL! B-MAX USES A LARGER VERTICAL SHAFT DIA. & LARGER SPLINE COUPLER. IM NOT SURE IF AN UPPER IS SOLD BY IT'S SELF. BUT I WILL FIND OUT. STOP BY OUR BOOTH IN CHAGO.( JR MARINE )I 'LL HAVE A B-MAX SETUP . RON BENDER
WILDTHING TAZ is offline
Old 12-25-2002 | 04:27 AM
Will "J" be there.I know "R" will be
enticer is offline
Old 12-25-2002 | 01:44 PM
B-MAX REPAIR
YES "J" WILL BE IN BOOTH ON FIRST DAY THEN HE'S LEAVING ME TILL THE WEEK END. HE HAS A COMPANY TO RUN. RB
Old 12-26-2002 | 11:06 PM
eliminator219's Avatar
Default Chicago show
Enticer,
Are you going to be at the chgo show? if so, what day? I would like to meet you and buy you a drink or two!! Have you sold your 33 yet? How much do you want? Sounds a little high to me,but we can talk about it!!
Do you have B-maxs? Are you not playing with the idea of surface drives?
Get back to me when you get a chance..
eliminator219
eliminator219 is offline
soinc
Drives and Lower Units
44
05-27-2009 09:20 AM
tblrklakemo
Active Thunder
16
08-09-2006 02:26 PM
Magicfloat
10
06-23-2006 10:53 PM
ONESICKGLADIATOR
03-03-2006 09:02 AM
Wally
05-06-2003 08:27 PM
