525 Sc With 200 Hours. Good Or Bad? >
Old 12-22-2002 | 06:29 PM
YELLOW FEVER
Default 525 Sc With 200 Hours. Good Or Bad?
I'M THINKING ABOUT BUYING A FORMULA POWERED BY MERC 525SC WITH 200 HOURS. WHAY DO YOU THINK OF THESE ENGINES? WHAT SHOULD I LOOK OUT FOR?
Old 12-22-2002 | 06:36 PM
mcollinstn's Avatar
Good motors if never overboosted. Came a little rich from the factory.
Run a compression check (or better yet, a leakdown). Look to see of you can tell if the heads have ever been off (broken paint on head bolts or repainted headbolts).
A stock 200 hour 525 should NOT have needed the heads off unless it blew a headgasket (lean mix, too much timing, low octane fuel, or too much boost).
Easy hopups are adding an intercooler and upping the boost to 6#.
mcollinstn is offline
Old 12-22-2002 | 07:40 PM
joeyoffshore
I have a pair in my 93' Cig with Blower Shops 250 blower, 240/hrs and don't burn a drop of oil.
lowblue320
09-24-2007 08:04 AM
lowblue320
0
09-22-2007 10:16 AM
PhantomChaos
16
01-14-2005 06:39 PM
MY OBSESSION
02-23-2003 04:29 PM
John B
09-21-2002 08:36 PM
