Bravo XZ drain plug washers (or not) >
Old 12-27-2002 | 10:24 AM
envision
Default Bravo XZ drain plug washers (or not)
I am refilling my Bravo XZ but there appears to be no washers on either the top or bottom drain plugs. I didn't see any come off.
There looks like a copperish colored band but it is very thin.
I checked on the BAM site and they show that the top screw definitely has a washer but I still am unsure about the bottom screw.
Anybody know for sure?
Thanks!
Old 12-27-2002 | 11:29 AM
Turbojack's Avatar
Mine has O-rings. Top & Bottom. I just drained oil this last weekend & checked the o-rings to make sure they were still OK
Turbojack is offline
Old 12-27-2002 | 12:10 PM
Dock Holiday's Avatar
Charter Member #34
Hope this helps. I just changed the oil on my XZ's a couple of weeks ago. This is the first time I did it myself.
All I had was the "copperish colored band" also. By accident I left the one off on the starboard drive on the lower drain plug. The next morning I had an ounce of oil on the floor.
Discovered what had happened, put the washer on and no problems.
Good luck
Dock Holiday is offline
Old 12-28-2002 | 05:47 PM
envision
Thanks guys.
I found that the copper washer does comes out when you least want it too like after the drive is full.
All back to gether now.
East Coast B
7
03-24-2007 11:06 AM
vandeano
20
11-02-2006 07:18 PM
ga1990
7
05-17-2005 01:50 PM
Kokopelli
8
05-24-2004 04:39 PM
Hot Boat
2
01-14-2003 07:57 AM
