Type paint for tabs? >
Old 01-05-2003 | 09:49 PM
kathycool's Avatar
Default Type paint for tabs?
What type paint and primer should I use for repainting tabs?
kathycool is offline
Old 01-05-2003 | 10:01 PM
KAAMA's Avatar
I know that this doesn't directly answer your question, but I had both trim tabs powder coated. I had both pieces (tab and transom mounting plate) painted. Four pieces all together for only $75 and they came out great.
KAAMA is offline
Old 01-07-2003 | 07:21 PM
572scarab
It depends how bad thay are.If thay are salt water chewed up then you really should take them off and sand blast them.320 sand them Then use a etch primer then a 2K primer then single stage urathane.Your done!!!write or print this take it to a jobber thay will help you on this
Zookeeper266
Detailing, Painting, & Fiberglass
15
10-01-2013 08:23 PM
screebar
6
02-08-2006 06:24 PM
BAJA WILL
04-06-2005 03:41 PM
buck183
7
05-05-2004 07:10 PM
Sonic30ss
Sonic
1
02-22-2003 09:58 AM
