Charging problems >
Charging problems
Charging problems
Old 01-10-2003 | 07:26 AM
Default Charging problems
I am having a problem with the starboard alternator. My gauge always reads between 10-11 volts. I had the alternator checked and it was fine. replaced the gauge and it read the same way. I'm thinking a wiring harness problem? I have heard that there is a wire going to the alternator that you can switch to a different post on the alternator so that it will think that the battery is not fully charged.??????? Any help or thoughts is greatly appreciated.
Thanks,
Jeff
Bajaforce is offline
Old 01-10-2003 | 09:17 AM
Wally's Avatar
Were doomed!
Does the voltage needle move lower when you turn on any acc switches on the dash? You probably have a bad ground in the dash harness somewhere...thats the first thing i would do is go over your connections. Make sure they are not loose or corroded. From there if it doesnt solve it you need to get a good volt meter and start working your way back towards the alt testing every so often to see what the voltage is.
-Wally
Wally is offline
Old 01-10-2003 | 09:27 AM
Audiofn's Avatar
Charter Member #232
Yup as Wally said get a good test meter and start to check thing out. First go to the battery and check voltage there. Make sure that your "excite wire" is seeing 12 volts when the engine is on (do this with the key in the run position NOT with the engine running of course). If the alternator is seeing the exite wire going to 12 volt then check the GROUNG on the alternaotor. Some just rely on the mounting area as a ground. I personally do not like this and when I see it I run a jumper wire over to the engine from the alternator. From there you will have to check your wireing. Look at all conections on the dash and on the engine plug and make sure that nothing has come loose. If you test the battery with the tester and find 14 volts then you can run jumpers up to the dash and see if you are reading the correct voltage also.
Jon
Put your best foot forward!
Audiofn is offline
David Stotz
Drives and Lower Units
6
09-18-2007 05:05 AM
offshoredrillin
9
08-16-2005 09:41 AM
cloudmaster_321
14
05-27-2005 10:58 PM
H20 Toie
Cigarette
4
05-26-2005 06:46 PM
THRILLSEEKER
7
04-28-2002 10:40 PM
