Coming Soon >
Coming Soon
Coming Soon
Old 01-23-2003 | 11:08 PM
HOUSTONPROP's Avatar
Lightbulb Coming Soon
Houston Propeller has aquired the domain name Bajapropellers.com and we will be setting up our own little site,I will continue to work with Blake and will also be here on offshoreonly but ,I love the name and will let you know when its up and running.
HOUSTONPROP is offline
Old 01-24-2003 | 01:38 PM
Dock Holiday's Avatar
Charter Member #34
Pretty COOL!!!!!!!!!!!!!!!!!
Dock Holiday is offline
Old 01-24-2003 | 04:11 PM
97BossHammer's Avatar
SWEEEEEEEET
97BossHammer is offline
Old 01-24-2003 | 05:05 PM
HyperBaja's Avatar
I will spread the word around here....
Tommy
HyperBaja is offline
Old 01-24-2003 | 05:44 PM
garshev's Avatar
Darrin, are you limiting your services to baja customers for any particular reason? I am still waiting to see how doc holidays props worked out for him as I plan on doing some b1's 28p this spring.
garshev is offline
Old 01-24-2003 | 10:52 PM
YEP!
And , I hear its pretty cool in North Carolina.Thank's DOCK It is pretty darn cold here too. Darin
Old 01-24-2003 | 11:12 PM
jcboats
darin:
that web site sounds awsome!!!
i will be ready to send my prop to you in feb.
i sent you am e-mail a few months ago.
here is my bio:
29 outlaw 502 mag mpi. bravo I
21 pitch 3 blade mirage
wot: 4900 rpm's 57 mph gps.
i am going to install a k&n air cleaner in the next 2 weeks.
should i go out and re-check readings prior to prop work??
i also will need some clean up work, there are nicks on all
3 blades.
jc
Old 01-24-2003 | 11:20 PM
Big E
Originally posted by jcboats
darin:
here is my bio:
3 blades.
jc
Hey JC - If you don't mind, let me know how your props turn out when you get them back from Darin. I was thinking about sending him mine just to get cleaned up. I am real interested to find out your results since we have the same boat (single 29 outlaw w/ 502 mag). Thanks - Eric
Old 01-24-2003 | 11:22 PM
Question maybe
maybe Doc will post a picture of the leading and trailing edges of his props and then look at yours? the rpm will come up and I hope the speed does as well. I should have put the satin finish on them like Mercury does ,but they dont look near as nice,we are not limited on repairs, as we do all types of props up to 36" in dia.It is the Mercury Mirage prop that I can get the most out of and you know how many Baja's have this prop on them. if the edges are razor sharp and slighty rounded its the best but they sure dont last very long.Doc's props are not, but they are alot thinner than stock.Darin
Old 01-24-2003 | 11:32 PM
Question lab now or later
it does not matter I am pretty sure what to do to get you some additional performance out of the stock Mirage prop you have and if I dont just send it back and no -charge to you we will do it again ,but you won't need to. Darin
