Help With Prop >
Help With Prop
Help With Prop
Old 02-10-2003 | 09:28 PM
82LAVEY's Avatar
Default Help With Prop
I have a 82 trs with a cleaver prop #487460021 i wanted to get a bigger prop but dont know what to get what will fit on my trs drive thanks
JOE
82LAVEY is offline
Old 02-11-2003 | 09:18 AM
throttleup's Avatar
Can you give me more details about your boat please.
Make, model, year of hull and drives, Motor size and rotation Current WOT and Speed...would be of help.
Julie
Throttle Up Propellers
www.throttle-up.com
throttleup is offline
Old 02-11-2003 | 02:01 PM
82LAVEY's Avatar
the boat is a 82 laveycraft supercruiser 23 ft long it has a 454 330 hp and a trs outdrive i dont know what the prop rotation is how do i check its runing at 5000 rpm wot the tag on motor puts wot at 4200-4600 rpm thanks for you time and help
JOE
82LAVEY is offline
Old 02-11-2003 | 02:20 PM
HyperBaja's Avatar
Look at the way the prop should turn, or if it is out of the water, hook up the flusher and turn it on, in neutral it will spin forward REALLY slowly. (well, at least on an alpha)
HyperBaja is offline
Old 02-11-2003 | 02:53 PM
JUSTONCE's Avatar
I'd guess trying a 23p mirage.
JUSTONCE is offline
Old 02-11-2003 | 03:07 PM
Wally's Avatar
Were doomed!
From the number on the prop you gave us it looks to be a 21 pitch prop.....and cleavers arent all that great for everyday use either....probably spins the RPM's up there while trying to get on plane...5000rpm on a stock 330 is pushing it!!...i'd definetly go to a biger prop like the Mirage 23 that was suggested. Best thing to try is find a buddy that has a bigger prop and see if they will let ya try it. Boats all seem to react differently but atleast you can get a good starting point.
-Wally
Wally is offline
Old 02-11-2003 | 03:40 PM
throttleup's Avatar
Joe,
Once again great advice here! I would recommend trying a Mirage Plus 23P. Your recommended WOT is 4600 to 5000.
This should bring your RPM down while still keeping you in your torque band. Try to find one locally to try. If you aren't sucessful give me a call and I will ship you one. Keep Us posted!
Julie
877-842-6855
Old 02-11-2003 | 04:05 PM
82LAVEY's Avatar
Thumbs up
A very big thank you to everyone I know nothing about outdrives
had a jet boat this one fell into my hands and loveing it so the jet is gone again thank you very mutch
JOE
82LAVEY is offline
Old 02-11-2003 | 04:29 PM
blue thunder's Avatar
You will get approx. 200rpm change with one inch prop pitch changed. Therefore, with a 23p mirage you could expect to run at 4600rpm (400 drop). I would prop your 330hp for about 4800 which would leave you needing a 22 inch pitch prop. Get the 23 mirage like everyone says and test it as is. Then if you don't like the boats attitude you could get the 23 mirage repitched to a 22 ($100). Labbing the 23 pitch could be another good option at that point for a little more jingle.
BT
blue thunder is offline
Old 02-11-2003 | 04:49 PM
throttleup's Avatar
BT:
Ditto...that is exactly where I would go!
