Drive Alignment??? >
Drive Alignment???
Drive Alignment???
Old 02-23-2003 | 09:12 PM
25 Eagle
Default Drive Alignment???
I know that the drive should be aligned periodically but for what reason other than getting grease to the drive shaft u-joints? How would you know if it were out of alignment? I get a vibration sometimes as I am pulling the stick back and coming off plane, anyone else? I am going to have this service done with 150hrs but was wondering what the whole thing is about Thanks
Old 02-23-2003 | 09:47 PM
Tinkerer's Avatar
If the engine mounts get loose then the alignment of the engine to the boat and drive will change. If that happens then you will soon lose a drive coupling that costs about $180 and You have to pull the engine to replace it. The vibration you are feeling may be caused by loose engine mounts or poor alignment. I pull my drives and check my alignment every year.
Tinkerer is offline
Cat-n-Around
08-20-2005 01:09 PM
gotime34
05-10-2005 10:16 PM
Krumbsnatcher
4
09-09-2003 08:18 AM
Andy
7
09-05-2003 09:41 AM
cheitman
17
02-20-2003 06:06 AM
