De- winterize boat? >
De- winterize boat?
De- winterize boat?
Old 03-22-2003 | 09:14 AM
CAP071's Avatar
Default De- winterize boat?
I have a 2000 502 Mag/Mpi It was fogged n winterized completely. Can I just charge the battery, squirt some oil in the cylinders, hook hose up , and start it, run it for 10 minutes, than shut it down for a complete tune up? Anything I should be aware of or look for?
CAP071 is offline
Old 03-22-2003 | 09:37 AM
formula31's Avatar
Do not even turn it over without water going to the pump. The impeller goes byby real quick. As a matter of fact, if the raw water pump is original, the impeller is due for replacement. I would pull the drive, grease the u-joints and check the alignment too. Check the torque on the u-bolt nuts at the top of the gimbal ring too.
formula31 is offline
Old 03-22-2003 | 09:42 AM
CAP071's Avatar
I have a new impeller n housing to install. How hard is it to pull drive? Do I fully remove it or just unbolt it and slide it back ? How do I check alignment? OH Boy here we go!
Hey HI-PERF 2000 where you at ?
CAP071 is offline
Old 03-22-2003 | 10:21 AM
HiPerf2000's Avatar
stop asking stupid questions you jackass.
i'll give you a hand.....but it sounds like you need the whole arm
HiPerf2000 is offline
Old 03-22-2003 | 08:41 PM
CAP071's Avatar
Sorry Formula I'm tryin to catch up with Hi Perf on the posts. I may consider doing a post on Bellie Buttons soon.
CAP071 is offline
85Baja
16
10-04-2008 12:05 PM
waterboy222
Grand Lake/LOTO/E-Dock
16
11-01-2007 02:15 PM
bn
5
09-29-2003 09:01 AM
Intolerant1
01-15-2003 10:29 PM
kook
5
10-14-2002 10:36 PM
