Help quick...No drain pug in lower unit!!!!!! >
Old 04-18-2003 | 08:27 PM
Default Help quick...No drain pug in lower unit!!!!!!
My drive has a cone that the previous owner installed..I think the epoxy or whatever mates the cone to the drive is now covering the drain plug....Is this common practice? How do I drain the drive? How do I fill the drive? What should I do? Help quick..I want to go boating tomorrow.
Shah Mat is offline
Old 04-18-2003 | 08:29 PM
mxz800's Avatar
if it is a low water pickup model the drain plug is behind the prop shaft and removal of the prop is neccessary for draining.
rob
mxz800 is offline
Old 04-18-2003 | 08:35 PM
Default Thanks mxz800
Yep, went out and looked, and there it was..
I love this board
Shah Mat is offline
Old 04-18-2003 | 08:44 PM
mxz800's Avatar
us checkmate guys gotta look out for each other
mxz800 is offline
Old 04-22-2003 | 09:36 PM
Elite Marine's Avatar
First time draining a Bravo 1 huh? I went through the same thing a couple years ago...thought I was cracking up!!!!
Elite Marine is offline
Old 04-23-2003 | 01:47 PM
Budman's Avatar
From: Kentucky - where the women are so fast we have to put a governor on 'em!!
A friend of mine who is a Merc mechanic said that they did that to force you to remove the prop when changing drive lube. Their reasoning was that that would prompt you to lubricate the prop splines. He said he has had many of them come into the shop where the prop had never been removed and was frozen to the shaft.
Budman is offline
PWRQWST
7
07-11-2006 10:32 PM
jcap
2
07-02-2003 06:22 PM
Waterfoul
05-19-2002 05:07 PM
blue thunder
27
03-18-2002 06:34 AM
pmichael
03-06-2002 12:13 PM
