vortec +ariz. speed and marine kits? >
Old 04-21-2003 | 07:24 PM
26sonic's Avatar
Default vortec +ariz. speed and marine kits?
for those that have the vortec maxflow or az speed and marine magnum kit , what are you setting your adj. fuel reg pressures?
i have a 1998 502 efi and set it 42psi, az speed and marine said 48psi? what is the pros and cons of setting to high or low?
26sonic is offline
Old 04-21-2003 | 09:02 PM
Ric232
AZ Speed & Marine also told me 48psi, so that's where I set it.
Downside to setting it too high: mainly that the motor may run a little rich a leave soot on your transom (mine does not).
Downside to setting it too low: KABOOOM !!
I would start at 48 and lower it if you get a lot of soot or if the engine stumbles at any point.
Old 04-22-2003 | 07:07 AM
hauling ass-a
set mine at 48 but the motor seems to load up need to start a post to find out where I went wrong. I think there may be a vacuum leak at the regulator. By the way the regulator sucks to get to!!!!!!!!!
Old 04-22-2003 | 11:22 AM
blown1500
Fuel mixture varries with the pressures. Higher pressures are richer. RIC 232 is right about the KABOOM if you get too low. Too low will also give a bad idle. I ALWAYS do what the programer (AZ Speed) says and talk to them BEFORE I change anything.
32HustSS
8
07-03-2007 09:56 AM
LAKESIDE RESTORATIONS
New Products and Member Discounts
5
05-03-2007 12:24 AM
teaguecustommarine
9
10-02-2006 05:51 PM
teaguecustommarine
5
09-27-2006 07:20 AM
26sonic
10
01-19-2002 09:58 PM
