Exhaust Tips >
Exhaust Tips
Exhaust Tips
Old 04-22-2003 | 08:22 AM
Default Exhaust Tips
Has anybody replaced the Corsa muffler tips with straight thru ones? If so, did the bolt hole patterns line up thru the transom? Which tips did you go with? After having two boats with the sweet sound of straight thru exhaust, the new boat just sounds too wimpy.
Jeff
Bajaforce is offline
Old 04-22-2003 | 10:12 AM
bcoffield's Avatar
Registered User
I had my tips replaced over the winter with Corsa straight pipes. Sounds great, throatily. I had the Dealer replacement them for me and they used the same bolt holes. The only think I would be worried about is when removing the old tips not to mess-up the finish.
Bill
bcoffield is offline
Old 04-24-2003 | 10:27 AM
srpbaer
Bajaforce,
Just did it yesterday....I used Eddie Marine long slant cut internal flappers, bolts lined up perfectly.....Sound great too.
See Ya
Old 04-24-2003 | 10:57 AM
outlawntexas
srpbaer,
How much trouble was it to get the old ones off? Any tips? I've got 2 engines to do.
Bruce...
Old 04-24-2003 | 09:05 PM
I replaced the corsa tips with angle cut tips from stainless marine w/ internal flapper.....hardest part is getting the rubber exaust tubing off and it's really not that hard.....the holes match up fine!
I used marine silicon to seal them.....the tips I had had the rubber gasket and it doesn't fit the regular tips....
I did it for the first time last year....you wont have any problems.
missouri is offline
Old 04-24-2003 | 09:13 PM
H2Xmark's Avatar
i think Nasdboy did his 29 and his were stuck on if I remember, if they break loose you are home free, I have heard of some being glued down pretty tight
H2Xmark is offline
Old 04-25-2003 | 07:30 AM
Highmark's Avatar
I had my dealer put the long slanted tips on my 33. Can't tell you how it sounds because I haven't had her in the water yet! My brother has a 275 w/ the 496 HO and the same tips. That engine almost sounds as nice as the 500 EFI. In my opinion it has a better (deeper) tone than the 502 Mag.
Highmark is offline
Old 04-25-2003 | 07:55 AM
dyno's Avatar
Charter Member #655
I have a set of angle cut tips with the flapps cut out if your interested....make me an offer.
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
bolgna
4
01-23-2008 06:23 PM
cowisl
01-16-2008 03:12 PM
thunderdan
01-07-2006 07:45 PM
carreraboat
5
02-20-2003 07:39 PM
CAP071
2
05-04-2002 11:31 AM
