Painting polished stainless? >
Old 04-30-2003 | 07:13 AM
Default Painting polished stainless?
Is there any certain precaution to painting polished stainless steel? special primer, or paint? Or does it cover just like any other steel?
THRILLSEEKER is offline
Old 04-30-2003 | 07:54 AM
later's Avatar
i would sand it good use a etching primer then a regular primer then paint.
later
later is offline
Old 04-30-2003 | 08:53 AM
ren3
Make sure that you unpolish it with 80-120 grit. Degrease with acetone. Prime it with an epoxy primer and paint with a good two part urethane such as Interthane Plus from Interlux. Easy to apply and readily available.
Old 04-30-2003 | 10:30 AM
Thanks for the help fellas, I just etched it real good with about 130psi. and a pot full of silica sand
Old 04-30-2003 | 02:00 PM
formula31's Avatar
That will work good, use a primer too.
formula31 is offline
Old 04-30-2003 | 09:23 PM
dougB
Question HOUSTON PROP/PAINTING S.S. PROP
it will never stay on. A omc painted stainless prop is teflon coated which in time still comes off on the tips of the blades.You could have the prop power coated and the insall a new hub insert if its rubber. Darin oh screen name still coming up dougb?????????????/
Old 05-01-2003 | 08:34 AM
KCHOTBOAT's Avatar
Charter Member #737
I had all my stainless steel powder coated several years ago and still looks great.
KCHOTBOAT is offline
502ss
9
10-16-2007 03:20 PM
rv
03-07-2007 04:56 PM
KEPP
New Products and Member Discounts
0
05-26-2006 05:59 PM
thisistank
08-23-2005 04:28 PM
US1 Fountain
03-06-2002 09:43 PM
