Valve Lash
Old 04-30-2003 | 06:18 PM
Default Valve Lash
I'm replacing valve springs and conponents on my 99 HP 500's and am getting conflicting answers. Mercruser says 1/2 turn and a respective offshore engine builder says 1 turn whom I also bought the parts from. Whats your opinion?
Goomba II is offline
Old 04-30-2003 | 07:20 PM
Vinny P's Avatar
I hate the winter!!
I have always gone with the 1/2 - 3/4 turn. But anywhere around that mark will work o.k.
Vinny P is offline
Old 04-30-2003 | 07:21 PM
Good question, I had several valves that would not quite down until 1 turn. After 50 hours of running I plan on going back and setting them at 5/8.
Tim T.
BadDog is offline
Old 04-30-2003 | 08:41 PM
paradigm shift's Avatar
You will probably get several correct answer to this. I as did BadDog have a set of hyd roller lifters that would make noise unless set at 1 turn down. I have for years ran hyd lifters at 1/2 turn with no trouble. Crane said to run them at 1 turn. Check www.cranecams.com if you want and you will see they recommend 1/2 to 1 turn or .020 to .060 preload. Good thing about hyd is they are some what forgiving on adjustment.
paradigm shift is offline
Old 05-01-2003 | 08:12 PM
Thanks for the replys I think I'll go 3/4 turn and be safe.
HARRISONMIRAGE
0
10-19-2004 01:35 AM
HARRISONMIRAGE
2
01-30-2004 10:09 PM
paradigm shift
5
08-25-2003 05:07 PM
seabeach
4
05-25-2003 02:06 PM
dyno
8
07-17-2002 06:54 AM
