Zero Cavity
Old 05-05-2003 | 02:08 PM
PULSEDRIVE
Default Zero Cavity
Before and after
Conversions #3 to Pulse Drives
Old 05-05-2003 | 02:09 PM
PULSEDRIVE
Old 05-05-2003 | 03:19 PM
PULSEDRIVE
Old 05-05-2003 | 03:32 PM
Payton's Avatar
Charter Member #927
Doc and Tony, that looks great!
Tony, I'm still looking for just the right project for those drives.
Payton is offline
Old 05-05-2003 | 03:51 PM
PULSEDRIVE
Just to show you how simple it is, Tim and I did the install in our spare time about 20 hours including filling the old holes.
When the sales Dept can do it any one can
Tony
Old 05-05-2003 | 03:54 PM
PULSEDRIVE
Old 05-05-2003 | 10:36 PM
imongo's Avatar
My only question is regarding Tony and Tim with the rubber gloves??? Is that really resin in the pot Tim?
Looks great! And, how does it run???
Mongo
imongo is offline
Old 05-06-2003 | 09:18 AM
dockrocker's Avatar
Interesting project! Looking at the 'after' picture, it looks like the "swim platform" over the drives is hinged (or otherwise articulated). I'm assuming that it moves with the drives, right? If so, can each drive be trimmed individually, or is the whole shootin' match moved as one unit?
Can't wait to see how these things perform....
dockrocker is offline
Old 05-06-2003 | 10:23 AM
PULSEDRIVE
The hole drive system trims as one
the aft underside of the drive works as a big trim tab at slower speeds hold the bow down and gets the boat on plane faster.
the curve underside of the housing directs water flow under the boat when backing allowing better thrust giving greater maneuverabilities
Have a look as www.pulsedrive.net for more info or call me direct at 954 788 0810
Tony Mills
P.S mongo, the gloves are to keep my hands silky smooth, the late nights alone with Tim and resign fumes haven't pushed me to the other side
Old 05-06-2003 | 01:40 PM
Panther's Avatar
Frank's Marine Service
Any test time yet?
Panther is offline
