Does fogging oil foul plugs? >
Old 05-07-2003 | 05:17 PM
Default Does fogging oil foul plugs?
Went to fire both motors today. 1 flooded and wouldn't start, the other runs great but if I hold it above 2000 rpm it sputters. When I do a couple of quick revs up to 3000 rpm it sounds fine, but after that if I try to hold it above 2000 rpm again it still sputters.
Could it be a foul/not firing plug? Or bad gas? Tanks are almost full but I don't remember putting in stabilizer.
Then I go back to the other motor, and wouldn't ya know it....the battery dies!!
Boy, I was so excited to just have them fire right up. Guess it is back to reality and scrambling to get it ready for memorial day!
Pure Energy is offline
Old 05-07-2003 | 06:31 PM
redscarab3's Avatar
Fuel is always the easy suspect.
But it really sounds like ignition. Spark plug wires or coil?
redscarab3 is offline
Old 05-07-2003 | 07:00 PM
eMotiondriver's Avatar
YES...
eMotiondriver is offline
Old 05-07-2003 | 07:08 PM
LapseofReason's Avatar
Does a bear chit in the woods.
LapseofReason is offline
Old 05-07-2003 | 07:29 PM
cig1988's Avatar
YES
cig1988 is offline
Old 05-07-2003 | 08:09 PM
That's helpfull
Old 05-07-2003 | 08:13 PM
bobby daniels
its most of the time plugs or ignition not gas unless its old as I am or full of water
Old 05-07-2003 | 08:15 PM
Just a smart a$$ yes to your ?, a yes just seemed bland and was already said
Old 05-07-2003 | 08:27 PM
i've always heard yank the plugs and bump the starter to spit out all the fogging oil.
funny thing is i had the same problem on my first boat. back when i knew realitively nothing about boats. mixed in some octane booster and changed the fuel/water seperator [fuel filter], new plugs and problem solved.
if it's your first run of the season i say change the fuel filter. and after burning that fogging oil, prolly the plugs as well
GameOver is offline
Old 05-08-2003 | 05:31 AM
cig1988's Avatar
I would replace the cap and rotor. Also check for any corrosion in the distributor.
cig1988 is offline
Magic1
5
10-28-2008 11:49 AM
BadDog
2
05-15-2007 01:44 AM
gripit
04-18-2006 07:56 AM
Sacandaga
4
09-04-2002 06:52 AM
97BossHammer
Baja
13
05-21-2002 07:38 AM
