Bravo XR question
My buddy has imco shorty lowers on his boat but it will be in the shop for a while and he offered to let me try them to see if they will improve my top end. Will imcos for a standard Bravo 1 fit into the XR upper?? Is the vertical different or the splines different?? ALso, can you just change out Flo-torq hubs to go from the standard to big shaft XR when swapping props??
Thanks,
Brett
Thanks,
Brett
Brett,
I believe they are the same. There is a standard coupler that connects the upper vert shaft to the lower vert shaft. It is the same for the XR and Standard Bravo. I see no reason for Imco to change that.
I believe the two would interchange.
Dick
Dick
1BIGJIM
Drives and Lower Units
3
06-10-2008 12:46 PM
pax2you
3
09-18-2007 09:07 AM
