ignition timing for initial start up? >
Old 05-30-2003 | 10:40 PM
Default ignition timing for initial start up?
for initial timing before I start up with no.1 on its compression stroke, do I set the rotor pointer @1 on the distributor with my damper reading zero, or my damper reading a few degrees before zero? I think the engine calls for 8degrees
THRILLSEEKER is offline
Old 05-31-2003 | 12:30 AM
mcollinstn's Avatar
connect all the plug wires to a spark block (a grounded metal plate with 1/8" spark gaps), put the timing light on #1, and set it at 8 before.
Can't really time one without a light, unless youplan to time by ear (do not recommend).
mcollinstn is offline
Nordicflame
18
03-22-2004 11:22 AM
convincor
6
06-16-2003 06:35 PM
THRILLSEEKER
4
05-31-2003 09:17 AM
Pure Energy
9
08-22-2002 10:40 PM
