Need some Help with a Leaky Bearing Seal >
Old 06-01-2003 | 08:27 PM
WetKitty42's Avatar
Default Need some Help with a Leaky Bearing Seal
Need help changer 256 Holly-Weiand Bearing Seal
I have a leaky bearing seal on my Holly-Weiand blower Drive belt Pully.
2001 575 SCI Motor
Where can I get a service manual?
Can I change the bearing seal without removing the bearing off the shaft?
Need some help here.
Fred
WetKitty42 is offline
Old 06-01-2003 | 10:54 PM
Not sure on the 250 blower, but I know on a B&M 174, the seal is just pressed in. Just needed to take off the pully, remove the seal and carefully tap the new one in.
Griff is offline
Old 06-01-2003 | 11:46 PM
WetKitty42's Avatar
Do I have to remove the Front Housing to get to the bearing seal?
Old 06-02-2003 | 12:28 PM
Not 100% sure on the 250's. On the 174, I just had to remove the top pulley and then pry out the old seal and press in the new one. It's very similar to seal for a harmonic balancer.
Is it leaking oil around the top pulley????
Griff is offline
puder
8
08-13-2003 02:22 PM
WetKitty42
1
05-31-2003 11:25 AM
imongo
2
08-15-2002 04:04 PM
jdnca1
4
06-27-2002 12:14 PM
blackhawk
2
05-11-2002 01:13 PM
