burning clutches? >
burning clutches?
burning clutches?
Old 06-02-2003 | 03:54 PM
yesrej's Avatar
Default burning clutches?
i have a omc king cobra outdrive. i was having shifting problems with it. i now know why i was having shifting problems. i have a burned out clutch. now my problem is, i just replaced the clutch last year at the end of the season. the clutch only has about ten hours on it. why am i burning up clutches. the outdrive is a 1990 with a cone clutch. if anyone has any clue of why i burned up this clutch so fast please let me know so i can put this boat in the water.
yesrej is offline
Old 06-02-2003 | 11:58 PM
mcollinstn's Avatar
sticky or misadjusted shift cable or linkage?
using cheap gear lube?
didn't get all the nast flushed out of the gearcase from the first clutch failure?
mcollinstn is offline
Old 08-30-2005 | 11:03 AM
Default Re: burning clutches?
I heard that with the OMC outdrive, if you do not use 100% synthetic gear oil, you may create a problem.
swood5991 is offline
ripley
33
06-19-2005 11:07 AM
force 320
5
02-11-2004 05:57 AM
Dock Holiday
10-13-2002 05:28 PM
