blown 520 idea...need roller cam advice >
Old 06-05-2003 | 06:34 PM
timucin's Avatar
Default blown 520 idea...need roller cam advice
which roller cam #?
planning to install a 8-71 blower
cr:9 to 1
everything forged inside the engine.
thnx
timucin is offline
Old 06-05-2003 | 07:10 PM
bobby daniels
WHAT TYPE ???? SOLID HYD ,,HEADS? COMPRESSION
Old 06-05-2003 | 08:33 PM
timucin's Avatar
compression : 9 to 1
solid
gm hi-perf rect port heads
timucin is offline
Old 06-06-2003 | 03:49 PM
bobby daniels
Something maybe 10* more on the exhaust than intake and 680 lift ,,,248*intake /@257* @50 lift 112 * lobes this would be a killer blower cam and still be very easy to drive around and turn
6200+ and be a torque monster
,,we have some ground for use and look at comp and crane or get Isky to grind it for you
Old 06-06-2003 | 06:02 PM
timucin's Avatar
thnx Bobbby but i coulndt fian a cam with your specs.where can i get them part#?
timucin is offline
Old 06-06-2003 | 07:06 PM
bobby daniels
I have either Isky or Ultradyne grind it but you can do that or just find one close
Old 06-06-2003 | 07:50 PM
timucin's Avatar
bobby : pls check your private message
timucin is offline
offthefront
Drives and Lower Units
6
09-14-2008 11:48 AM
ghittner
19
05-14-2007 05:36 PM
daboatman1
10
12-16-2004 09:37 AM
X-Rated30
3
07-28-2003 03:34 PM
MYPANTER24
Pantera
4
12-26-2002 03:48 PM
