Go Back  Offshoreonly.com > Owners Forum > Sutphen
Ocean Pacer question >
Old 06-10-2003 | 12:52 PM
Default Ocean Pacer question
This may sound like a stupid question but how many fuel tanks does a 1986 Ocean Pacer have? I am assuming 1, but there are two fuel caps one on each side of the boat. I am assumi9ng again that this was for ease in filling or am I all wrong. There is only one fuel guage..
Help
SinkorSwim is offline
Old 06-10-2003 | 02:26 PM
BODYSHOT1's Avatar
Default s/b two
probably have one per side....I know the race versions had saddle tanks...in the engine compartment.
BODYSHOT1 is offline
Old 06-10-2003 | 02:48 PM
Default Ok,,,,next question
Is there a fuel pump that controls the fuel flow or does it just draw from either side.....or one motor from one side and visa versa......
Old 06-10-2003 | 03:09 PM
BODYSHOT1's Avatar
again..I'm going by the race version...which had fuel pumps for each tank...really not sure about the "civilian" version...
some of the other guys on the board may know better.....
Old 06-10-2003 | 03:13 PM
later's Avatar
ID BEING WILLING TO BET THAT YOU HAVE TWO TANKS ONE FOR EACH MOTOR THATS HOW FOUNTAIN AND OTHERS DO IT.
LATER
later is offline
Old 06-10-2003 | 08:38 PM
454hoho
Talking
yoooo Marty, was down smitty`s the other day and your partner was working on the boat. are you going to run the Pt.plesant race
Old 06-10-2003 | 09:27 PM
bob
Charter Member #40
Non race Sutphen's typically have a fuel fill on each side with one tank under the cockpit. Tank typically runs from the engine compartment bulkhead and goes forward, in the keel area of hull. Two fills make it nice when filling, use one as a vent and you can pour the fuel in quick!
bob is offline
Old 06-11-2003 | 07:01 AM
Thumbs up Thanks for all the help :)
Largest knowledge base on offshore boats in the world right here....!
Old 06-11-2003 | 09:34 AM
BODYSHOT1's Avatar
hey!..sorry I missed you....we should be a "go" for Seaside next week....
waaazzzzuuup with your ride??
Marty
Old 06-11-2003 | 03:43 PM
Darkhorse468
Hey Sink or Swim
I own a "pleasure version" of the 30' Sutphen an 83 and the info your getting is 100%. It is one 150 gallon tank with the fuel fills to each side(look under rear bench seat and you'll find fill hoses, feeds and shut-offs). I mounted two Holley blue pumps on the bulkhead, one for each motor, to help feed the mechanicals on the motors. Might seem like over kill, but feeding a big block revving around 6000rpm takes big, consistant fuel pressure. My experience on this sight with info has been excellent. It seems this Sutphen society sticks together BIG TIME. No matter what the question, you'll get some kind of good info or even just a guiding word. HEY SUTPHEN 30, FOBES, ETC. WHERE ARE YOU GUYS???
