xr drive blowing oil out of res. >
Old 07-01-2003 | 06:27 PM
jcap's Avatar
Default xr drive blowing oil out of res.
xr with imco lower less than 20 hours , repowered this winter slightly more hp , (720hp) and the resevoir emptys when run hard, my engine builder did rmove and reinstall the lower(tried a shorty)the hp increase was slight and i didnt hav this prob before,my builder claims its the drive getting hot ( i do hav a shower) and i should just keep a drop in the bottle when cold than when hot it wont overflow? any thoughts?
any aftermarket bottles that a better than mecr plastic crap?
jcap is offline
Old 07-01-2003 | 06:54 PM
jcap's Avatar
I never remember to do searches! lots of good info , hopefully bad cap , probably air , and i ran it hard for 4 or 5 hours!I guess ill need to check for heat damage
jcap is offline
Old 07-05-2003 | 05:48 AM
GLH's Avatar
GLH
I had this problem and tried a TON of things Ended up it was a bad cap. Switch them if you have twins or buy 2 or 3 and try new one there only $6 each.
GLH is offline
Old 07-05-2003 | 07:51 AM
jbrauer's Avatar
1 - Swap caps.
2 - Try Merc Hi-Performance gear lube.
3 - As the fluid cools after use is the level lower each time? If so, might be a leak. If there is a leak (seal or gasket) it can also suck air and cause foaming. Mine did when the input shaft seal failed.
Good luck!
jbrauer is offline
Old 07-05-2003 | 12:03 PM
Strip Poker 388's Avatar
Rob
I have heard its water foaming up when it over flows the color of the oil will change if its water. On my old Scarab with a blown motor and it had a Imco drive on it with alysyn syn oil in it, it would foam up ,it was the oil ,i put merc oil in it and it quit. My Hustler has B-Maxs on it and they come with a larger reservoir and only put 1 inch of oil in it and it foams about 1 more inch when you run it hard .i use amsoil in it.. but no problems with it, when the air settles it goes back down. Someone else said it just the syn type oil that does it.make sure on the drive the oil passage between the foot and top align up theres a orange seal there.i have heard they can get water in from there. good luck.
Rob
Strip Poker 388 is offline
Plane Silly
Drives and Lower Units
4
09-08-2008 12:21 AM
glassdave
05-22-2008 11:37 PM
Bryan Rose
2
05-18-2008 03:16 PM
29KILROY
2
08-18-2005 06:21 AM
SIZE MATTERS
11
10-07-2004 02:05 PM
