oil pressure guage flickering from normal to pinned, then back
oil pressure guage is flickering on occasion from normal (55psi) to pinned above 80, then back.
is the sending unit bad/going bad and shorting internally?
I think Rambunctious is right. One of the engines in my 32 Fountain did the same thing over the weekend for a few minutes. Had me startled at first, but since it did not last, I figure the sender was probably sending faulty info to the gauge.
I just had the same problem, thought it was the guage, (Gafrigg) so I replaced it still had the same problem. Checked the connections still the same, pinned passed the reading of the guage. Replaced the sending unit on the carb rail and all was perfect. Hope this helps.
JGB
21
02-08-2011 11:24 AM
