Black Transom problem >
Old 07-13-2003 | 09:38 PM
N2BOATN
Angry Black Transom problem
My boat has twin 350 mag's efi/mpi with the stock flame arrestors there was a little sooting ,,,,well I thought I would try a K&N , put them on Friday and went to the lake today, and when I crank it up it looks like black dust floating on the water and the transom was really black when I pulled the boat out . Do you think that the ecm's need programing because it is getting more air????? any help or advise in greatly appreciated
Old 07-13-2003 | 09:51 PM
MACDAD260's Avatar
Charter Member #818
Sounds like the K&Ns are restricting the air and causing a richer mixture. Try it without any flame arresters and see what happens. If it runs clean without any flame arresters than you will know that the K&Ns are causing more air restriction than the stockers. Not supposed to, I know, but maybe they are.?
MACDAD260 is offline
Old 07-13-2003 | 10:33 PM
What octane gas are you running????? You should run the LOWEST recommended octane for your engines--87? It will burn more completely with less black residue and give the best performance.
Griff is offline
Old 07-14-2003 | 03:13 PM
formula31's Avatar
The K&N's I bought for my engines were way too small even thought they were the ones recommended by them. Lost 400 rpm. Like Macdad said, take them off and try again.
formula31 is offline
MikaylaHunterCig
6
03-03-2006 12:20 PM
MikaylaHunterCig
02-27-2006 03:45 PM
G Man
Detailing, Painting, & Fiberglass
50
02-22-2006 10:23 PM
ApachePete
04-11-2004 04:55 PM
Audiofn
5
09-30-2002 08:51 PM
