Shifting ????'s >
Shifting ????'s
Shifting ????'s
Old 07-24-2003 | 10:19 AM
bowtie89
Default Shifting ????'s
When I shift into gear everything is fine but when I take it out of either gear it seems like it kills for a little to long and almost stalls. out of the water is fine but in the water it does this. What do you think I should adjust or is this how I am going to live with this???
Old 07-24-2003 | 10:40 AM
Scott72
Being an Alpha drive, you have something that is called an "interupter". When you shift it momentarily kills the motor. It is located were the shift cables are mounted on the starboard side exhaust manifold. This probably needs to be adjusted. I have never done it, but I think it is pretty simple. I'd check a Mercuiser manifold to see how to adjust it.
Old 07-24-2003 | 10:42 AM
Mbam's Avatar
Offshoreonly Advertiser
Check out this on our web site -
http://go-fast.com/mercruiser_alpha_shift_problems.htm
Mbam is offline
Old 07-25-2003 | 08:14 AM
JON242
First thing to do is adjust the cables properly. Other than that the most likely thing is a bad shift cable. It has to move very freely otherwise it will put too much pressure on the interrupter switch spring and cause the motor to die. I think you just changed that cable so make sure its not kinked.
aviatorg3
Ocean Express
14
02-10-2008 10:35 AM
awsomethunder
Drives and Lower Units
20
06-04-2007 07:32 PM
BillR
6
05-08-2006 11:15 AM
24Baja
9
10-15-2004 06:33 AM
24Baja
1
09-21-2004 09:53 PM
