Bravo I lower gears??????? >
Old 07-27-2003 | 09:35 PM
Default Bravo I lower gears???????
OK.....with Bravo I lower halves. Are there different gear ratios? For example:
A: 1:36 outdrive
B: 1:50 outdrive
Do they both have the same gears in the lowers and the uppers is what makes the gers ratios different?
Or do I have this wrong?
I have a few lower halves (stock) that came off of 1:36's .... So, perspective buyers ask what ratio....are the lowers.......good question.........I thought they were the same
enticer is offline
Old 07-28-2003 | 08:57 PM
WILDTHING TAZ's Avatar
B-MAX REPAIR
NO 1.50 & 1.36 HAVE TOTALY DIFFERENT TOOTH COUNTS ,UPPER AND LOWER
WILDTHING TAZ is offline
Old 07-28-2003 | 09:42 PM
Mbam's Avatar
Offshoreonly Advertiser
Taz, not true. Not trying to be argumentative, but regular or XZ B1 changes ratio in the upper (3 choices), only 1 lower gear set.
XR has 1 upper ratio, changes ratio in lower (again 3 choices).
I never did try to work out all the ratios that would be available with stock upper and XR lower gears.
Mbam is offline
Old 09-02-2003 | 03:55 AM
RhinoX
you are correct, LOWER ratio is changed on XR
gear count
1.5 = 15/19
1.35 = 15/17
1.26 = 17/18
with standard straight cut XR 16/19 upper gears
many combinations possible with different XZ upper gears
Old 09-02-2003 | 10:16 AM
Dennis Moore
All Bravo One Gasoline lower gearcases have the same gears. Bravo XR and diesel have different gears.
bor
Drives and Lower Units
1
01-23-2008 09:45 PM
HPJunkie
10
03-01-2007 08:38 AM
Vinny P
12
10-21-2006 12:34 AM
Phantom1
07-25-2005 10:25 AM
