OT: Car starter issue >
Old 07-28-2003 | 03:52 PM
Phknlwyr's Avatar
OffshoreOnly Antagonizer
Default OT: Car starter issue
1997 Toyota 4Runner w/ 70000mi. When I turn the key, it (the engine/starter) often does nothing. There is no sound no turning, nothing. On the second turn it usually fires. Lately, it has taken three to four key turns to get the starter to turn at all. Is this a problem with the starter, battery, or something else? Any input is appreciated.
"Kevin, prepare for the summer."
-Mr. Sorkin, 10th Grade Geometry teacher
Phknlwyr is offline
Old 07-28-2003 | 06:59 PM
Vinny P's Avatar
I hate the winter!!
This should be simple enough to diagnose. You have to ground the clip of a test light, then put the probe on the small wire on the starter motor. This must be done when the starter wont turn over. If the test light illuminates and the starter doesn't turn, the starter is bad. If the light doesn't illuminate, then there is a wiring problem. If you give me more specifics, like engine size, I can e-mail you or post a copy of the wiring diagram for your truck.
Vinny P is offline
Old 07-28-2003 | 08:09 PM
Phknlwyr's Avatar
It has a V-6.
Phknlwyr is offline
Old 07-28-2003 | 08:29 PM
MACDAD260's Avatar
Charter Member #818
If the test light does not indicate power getting to the starter then it is probably the ignition switch. They do wear out sometimes and need to be replaced.
MACDAD260 is offline
Old 07-28-2003 | 08:35 PM
97BossHammer's Avatar
I was going to say ignition switch as well....had this happen on a different vehicle but same type of problem.
97BossHammer is offline
Old 07-28-2003 | 11:02 PM
mcollinstn's Avatar
ground wire
battery connection
ignition switch
solenoid
mcollinstn is offline
Old 07-29-2003 | 04:52 PM
Vinny P's Avatar
I hate the winter!!
I tried to post the diagram for you. But, I can't figure out how to get the picture resized to fit. PM me your e-mail address and I will send it directly to you.
Vinny P is offline
Old 07-29-2003 | 05:12 PM
NASTY HABIT's Avatar
try calling a phknmechanic or take it to the phkndealership sorry just had to...
NASTY HABIT is offline
Steel Outlawed
22
04-06-2009 01:58 AM
russ
0
07-21-2005 04:35 PM
blue thunder
16
01-17-2002 09:45 AM
