94 Dodge Ram Ignition Problem >
Old 08-21-2003 | 12:57 PM
Default 94 Dodge Ram Ignition Problem
Anyone have problems with the ignition on a Dodge Ram. The Starter doesn't seem to be getting any power when I turn the key. Won't even click. It's a diesel and both batteries are good.
NickOTeen is offline
Old 08-21-2003 | 07:53 PM
Vinny P's Avatar
I hate the winter!!
If you want, I can forward you a wiring diagram for this truck. Just send me your e-mail address and the model truck and engine size.
Vinny P is offline
Old 08-21-2003 | 10:41 PM
robyw1's Avatar
You know what? This is going to sound real stupid but if you get under it and tap on the starter motor with a hammer, I bet it will start. If it does then you will need to purchase a new starter. The contacts get dirty and hitting it with a hammer will dislodge some of the burned gunk off the contacts. I have been doing this for years and that has always worked. Now you will only be able to get away with this a few times until the contacts got so dirty that it just won't work anymore.
Roby
robyw1 is offline
Old 08-22-2003 | 10:08 AM
Thanks for the responses. The starter is not bad. Something is broke in the steering column, and it's going to have to be taken apart. The starter is good, I just can't get it to engage.
Old 08-22-2003 | 01:34 PM
V_P
Default Re: 94 Dodge Ram Ignition Problem
There was a recall on the ignitions of some of the
heavy duty trucks. I can't remember all of the details
of the recall but it involved wiring in a relay under the
dash because some of the ignition wires going directly
to the ignition switch were burning up. Too much draw
on them.
I was a tech at a Dodge dealer, its been
a few years since I've turned wrenches and I don't
remember all the details of that recall, but that could
be your problem. If you're not sure if that recall has
been done or not, call the dealer.
V_P is offline
freshwaterfiend
12
02-01-2008 08:38 PM
gotime34
18
10-02-2006 04:13 PM
Canada Jeff
10
11-02-2005 05:24 AM
Tantrum
10-16-2002 11:23 AM
