Laser Temp Sensor
Old 08-25-2003 | 04:11 PM
Default Laser Temp Sensor
Where can I get a decent laser temperature sensor?
Anyone have any history with a specific brand?
thanks
Shawn
shawn is offline
Old 08-25-2003 | 04:18 PM
WHITE-DIAMONDS's Avatar
Funny.....I was just now trying to get the same information....I know you can get a cheapo from Radio Shack for $30 and you can get a Stanley for $100.
I would like to know as well if price does matter on one of these units??? Which brand is good for the money??
WHITE-DIAMONDS is offline
Old 08-25-2003 | 04:51 PM
R Addiction's Avatar
AT Cult Member #3
Raytec makes a 100$ unit. I use one at work, works well!! Talk to any tool men they all stock 'em.
R Addiction is offline
Old 08-25-2003 | 04:52 PM
Scott's Avatar
Charter Member #30
I keep a Radio Shack unit on the boat. Had to do some quick comparison checking last week and gave me piece of mind that it was a gauge problem and not the motor.
Keep in mind your not trying to compare temps in some nuclear fusion experiment if you just need to be close then save the $ and buy the Radio Shack unit.
I have also compared it with room thermometers and it has been right on with them.
I have Steps & Bubbles!
Scott is offline
Old 08-25-2003 | 05:05 PM
Sydwayz's Avatar
Forum Regulator
Send a PM to 'skater'. Mark has one that I have used before, and it works well. They depend on it for the race boats.
Sydwayz is offline
Old 08-25-2003 | 05:07 PM
Dock Holiday's Avatar
Charter Member #34
I bought my Raytec from WW Grainger, basic model was around $90.00 if my memory serves be right. I have had it a couple of years now and it is the best money I have spent.
They have a thousand uses, but I mainly use mine to check tire and hub temperatures on the trucl and boat trailer when I trailer long distances.
There is no better way to tell if a tire is fixing to go on you.
Dock Holiday is offline
Old 08-25-2003 | 05:36 PM
Turbojack's Avatar
Are you seeing that your back hubs are running hotter that the other ones. My front & back axle both have brakes & the rear axle is running about 10-20 degrees warmer.
Turbojack is offline
Old 08-25-2003 | 07:22 PM
Ted G's Avatar
The RS one works fine, just doesn't have the laser in it. I use one all the time and it is very accurate. Remember too that most times you are doing relative temps on a boat so it is fine.
www.cbpba.com
Ted G is offline
Old 08-25-2003 | 07:57 PM
GO4BROKE's Avatar
The lasers the fun part! I have a raytec, lately the wife uses it to check oven temps.
[img][/img]
GO4BROKE is offline
Old 08-25-2003 | 10:19 PM
Mr. Demeanor
I got the small Raytech at Napa last year for $60. The laser is nothing but a pointer to let you know exactly where your getting the reading from. Shiny surfaces will give you erratic readings.
cloudmaster_321
Do It Yourself, Boating on a Budget
2
10-19-2008 07:14 PM
ak
0
04-30-2008 11:02 PM
BigFish
31
12-30-2007 06:57 AM
stevesxm
9
12-22-2005 02:02 PM
Steel Outlawed
6
03-30-2005 04:49 PM
